Vecchio 17-10-2008, 13:37   #1
filli
L'avatar di filli
Registrato dal: Jul 2008
residenza: Milano (Arese)
filli is on a distinguished road
consiglio tra 5 motori qualita'\prezzo
Ragazzi chiedo un vostro consiglio visto che una candela ha gentilmente lasciato cadere il suo filamento all'interno del motore rigandomi il cilindro con gentilezza...(AZZ).. quale scegliereste fra questi motori x il vostro truggy....
o scegliereste altro..
go tecnology .25 6 port race 209.99 usd
Specifications:
Maximum power: 2.70 hp
RPM: 34,000 rpm
Practical RPM Range: 4,000 - 40,000 rpm
Bore: 16.26mm
Stroke: 16.80mm
Crankshaft: 14mm SG
Glow Plug Type: Standard
Exhaust Type: Rear
Werks Racing Team Line B7 Pro-C .28 Competition 7-Port Truggy Engine 209.99 usd
Displacement: .28cu (4.6cc)
Max RPM: 38,000
Horsepower: 2.95
Sleeve: ABC
Ports: 7
Bore 0.69" (17.46mm)
Stroke 0.72" (18.4mm)
Carburetor Bore: 0.31" (8mm)
Crankshaft Bore: 0.38" (9.75)
Crankshaft Diameter: 0.56" (14.2mm)
Exhaust: Rear
Carburetor Material: Composite
Rear Bearing: Ceramic Ball Bearing
Weight: 8.1 oz (230g)
Axial .28 Spec 1S Engine w/Pullstart 109.99 usd
Specifications
Size: .28cubic inch/4.6cc
Maximum RPM: 36,000
Bore: 18.6mm
Stroke: 16.9mm
Construction: ABC
Heat-sink Head: Green Anodized Aluminum
Carburetor: 8.5mm Composite Slide Carb
Carburetor: Adjustments 3 Needle, Flush Settings
Case: Black Aluminum, Rear Exhaust
Connecting Rod: Dual Bushing
Sleeve: 8 port
Starting system: Pullstarter
Recommended Glow Plug: Cold-5 Power Plug/ O'Donnell #99 (Any other brand standard length non turbo cold glow plug will work also)
Axial .28RR Pro Off Road Competition Engine 164.99 usd
Specifications:
Size: .28 cubic inch/2.09cc <--- (questa cilindrata credo sia sbagliata ma
e' la descrizione originale)
Maximum RPM: 38,500
Bore: 18.25mm
Stroke: 17.5mm
Construction: ABC
Heat-sink Head: Green Anodized (optional Grey available)
Carburetor: 9.0mm Composite Slide Carburetor (includes optional 8.0 & 8.5mm venturi’s)
Carburetor Adjustments: 3 Needle, Flush Settings
Sleeve: 7 port
Go Technology .28 6 Port Race Engine 209.99 usd
di questo purtroppo non ho la descrizione..
li potete trovare da a main hobbies...
http://www.amainhobbies.com/index.php/cPath/1_23_79
go25.jpg‎   wrxtl28b7proc.jpg‎   axi001.jpg‎   axi0330.jpg‎   go28.jpg‎
Smanett...Smanett...
When in trouble gas it..!!
Ultima modifica di filli; 17-10-2008 a 13:41
filli non è in linea   Rispondi quotando
Vecchio 17-10-2008, 14:26   #2
L'avatar di lelenonmolla
dei 5 il migliore secondo me e' il GO 25 la spesa vale la resa
Vecchio 17-10-2008, 19:48   #3
Alexio
Alexio is on a distinguished road
Tra questi 5 non saprei, ma perché non ti rivolgi al mercato Italiano?
Un Picco .28, normale o Fastrace lo prendi in Italia con 200 euro, ed è un ottimo motore. Lo stesso discorso vale per il Novarossi .28 Plus 3 luci, che trovi anche con avviamento roto.
Alexio non è in linea   Rispondi quotando
Vecchio 17-10-2008, 19:54   #4
Alexio
Dimenticavo...hai provato a sistemare il tuo? Lo smonti lo pulisci e lo provi, non è detto che non vada.
Vecchio 17-10-2008, 20:34   #5
Amer
L'avatar di Amer
Registrato dal: Sep 2008
residenza: Torino
Amer is on a distinguished road
Io possiedo Axial 28 spec. Gran motore, cattivo, cattivo ma da carburare e una bestemmia continua d'altronde come tutti gli 8 travasi.
Amer non è in linea   Rispondi quotando
Vecchio 17-10-2008, 22:43   #6
pinokyosho
L'avatar di pinokyosho
residenza: Larino
Età : 63
pinokyosho is on a distinguished road
Wink
ciao io giro con un sts 28 e va molto bene tranquillo quanto basta e cattivo quando lo si chiede,non spegne mai e una volta carburato bene(ed è una cosa molto facile)non spegne mai.....lo trovi a 130€ spedito...poi se ti interessa ho un falcon con neanche 2 lt consumati lo do via a 160€ spedito.....ciao pinuccio...
pinokyosho non è in linea   Rispondi quotando
Vecchio 18-10-2008, 12:32   #7
filli
L'avatar di filli
Originariamente inviata da Alexio Visualizza il messaggio
si ci ho provato ma oltre ad una bella riga sul cilindro e' anche scavato il pistone creando un bel passaggio tra camera di combustione e albero,in piu si sono creati dei piccoli segni nel carter che secondo me disturbano il passaggio della miscela e spendere dei soldi per l'accoppiamento quando non so se il carter vada bene non me la sento,comunque dopo averlo rimesso in moto e' diventato impossibile da carburare e il minimo lo tiene solo molto alto.
PORK NON AVEVA NEANCHE 4 LITRI!!!
appena posso vi posto delle foto.
Vecchio 18-10-2008, 18:27   #8
sul truggy attualmente il top è senza dubbio l'os 28 xz, ultimamente vanno forti anche i Fox .24, fra quelli fra te elencati a me piace molto il werks....
Vecchio 20-10-2008, 15:09   #9
filli
L'avatar di filli
io lo montavo di serie e mi piaceva pure parecchio..non sai dove trovarlo in italia o dove trovare i ricambi?
Vecchio 20-10-2008, 15:12   #10
filli
L'avatar di filli
Originariamente inviata da pinokyosho Visualizza il messaggio
Grazie puo' essere un idea.....dove posso trovarlo a 130 euri?
Motori per....... Rouge711 Motori 3 19-12-2007 16:58
Qualità X1 CRT...al top :) Bestia Truggy OFNA 85 31-05-2007 14:22
carbonio a prezzo umano...... emmedi40 Negozi 21 21-05-2006 20:31
Consiglio su motori Vulcanino Motori 32 14-03-2006 08:31
CUSCINETTI DI ALTISSIMA QUALITA' plecofish Negozi 1 05-03-2006 20:35
Tutti gli orari sono GMT +1. Attualmente sono le 12:20.
