Vecchio 17-10-2008, 13:37   #1
filli
L'avatar di filli
Registrato dal: Jul 2008
residenza: Milano (Arese)
consiglio tra 5 motori qualita'\prezzo
Ragazzi chiedo un vostro consiglio visto che una candela ha gentilmente lasciato cadere il suo filamento all'interno del motore rigandomi il cilindro con gentilezza...(AZZ).. quale scegliereste fra questi motori x il vostro truggy....
o scegliereste altro..
go tecnology .25 6 port race 209.99 usd
Specifications:
Maximum power: 2.70 hp
RPM: 34,000 rpm
Practical RPM Range: 4,000 - 40,000 rpm
Bore: 16.26mm
Stroke: 16.80mm
Crankshaft: 14mm SG
Glow Plug Type: Standard
Exhaust Type: Rear
Werks Racing Team Line B7 Pro-C .28 Competition 7-Port Truggy Engine 209.99 usd
Displacement: .28cu (4.6cc)
Max RPM: 38,000
Horsepower: 2.95
Sleeve: ABC
Ports: 7
Bore 0.69" (17.46mm)
Stroke 0.72" (18.4mm)
Carburetor Bore: 0.31" (8mm)
Crankshaft Bore: 0.38" (9.75)
Crankshaft Diameter: 0.56" (14.2mm)
Exhaust: Rear
Carburetor Material: Composite
Rear Bearing: Ceramic Ball Bearing
Weight: 8.1 oz (230g)
Axial .28 Spec 1S Engine w/Pullstart 109.99 usd
Specifications
Size: .28cubic inch/4.6cc
Maximum RPM: 36,000
Bore: 18.6mm
Stroke: 16.9mm
Construction: ABC
Heat-sink Head: Green Anodized Aluminum
Carburetor: 8.5mm Composite Slide Carb
Carburetor: Adjustments 3 Needle, Flush Settings
Case: Black Aluminum, Rear Exhaust
Connecting Rod: Dual Bushing
Sleeve: 8 port
Starting system: Pullstarter
Recommended Glow Plug: Cold-5 Power Plug/ O'Donnell #99 (Any other brand standard length non turbo cold glow plug will work also)
Axial .28RR Pro Off Road Competition Engine 164.99 usd
Specifications:
Size: .28 cubic inch/2.09cc <--- (questa cilindrata credo sia sbagliata ma
e' la descrizione originale)
Maximum RPM: 38,500
Bore: 18.25mm
Stroke: 17.5mm
Construction: ABC
Heat-sink Head: Green Anodized (optional Grey available)
Carburetor: 9.0mm Composite Slide Carburetor (includes optional 8.0 & 8.5mm venturi’s)
Carburetor Adjustments: 3 Needle, Flush Settings
Sleeve: 7 port
Go Technology .28 6 Port Race Engine 209.99 usd
di questo purtroppo non ho la descrizione..
li potete trovare da a main hobbies...
http://www.amainhobbies.com/index.php/cPath/1_23_79
Immagini allegate
Tipo di file: jpg go25.jpg‎ (51.0 KB, 3 visite)
Tipo di file: jpg wrxtl28b7proc.jpg‎ (48.1 KB, 4 visite)
Tipo di file: jpg axi001.jpg‎ (57.7 KB, 3 visite)
Tipo di file: jpg axi0330.jpg‎ (58.8 KB, 2 visite)
Tipo di file: jpg go28.jpg‎ (53.3 KB, 1 visite)
Smanett...Smanett...
When in trouble gas it..!!
Ultima modifica di filli; 17-10-2008 a 13:41
Motori per....... Rouge711 Motori 3 19-12-2007 16:58
Qualità X1 CRT...al top :) Bestia Truggy OFNA 85 31-05-2007 14:22
carbonio a prezzo umano...... emmedi40 Negozi 21 21-05-2006 20:31
Consiglio su motori Vulcanino Motori 32 14-03-2006 08:31
CUSCINETTI DI ALTISSIMA QUALITA' plecofish Negozi 1 05-03-2006 20:35
Tutti gli orari sono GMT +1. Attualmente sono le 04:52.
